The driveshaft for an original Mustang 9" is one inch shorter than the one for the 8". Unless it was changed in its life, the yoke is a long one. If the donor car still has the driveshaft, it will fit your car as will any driveshaft from a 67-70 Mustang/Cougar that was equipped with a 351w or larger engine (all of which happen to have 9" rears.) As mentioned, alternately the yoke on the rear can be swapped for the short one (with a new crush sleeve.) The short rear yoke (28 spline) is actually quite common as it is used on many aftermarket performance rears and can be found on some factory stuff, like the 57-59 full sized Ford. Yes there can be differences in the U-joints used, the 1310 and the 1330 or a combo of both.
