Have your 87-93 door belt moldings seen better days? grab a set of our NEW OEM ones for your stang!!! http://www.mcrparts.com/shop/87-93-d...D-p-18891.html
I need some help with this too.... I just picked up a 91 gt and the belts and dew wipes need replaced.... How easy/difficult is it???
the belts are super easy, just open your door, and look where the molding ends and there is a screw. Once Screw is removed, the bolt molding just slides out.
Hell the way mine are you can just give them a little tug and the old ones are off due to the rust around the rivets. I'm a little confused. The pics show the trim that goes overtop but I pictured the door belt weather stripping (against the glass) which is where the rivets are.
If you take off the outer door belt molding, you will see the rivets on the outer door belt. We also sell screw kits if you would rather do that then rerivet them back in. Tony
