so the rear of my stang was sagging and i went to the parts store and purchased a set of shocks and installed them... and the pass side raised up some but the driver side still look low... one of the boxes did have the washers and bushing missing so i just installed it with the old one... driver side.. side that is low .. would them bushing make it sag.. there was only like a 1/8" shorter than the other one (new one) or do i just have bad springs also..replaced them with monro sensatrack shocks.. any idea
Shocks don't really determine ride height. There are many things that cause rear sag on a fox. In most cases its the springs and worn spring isolators.
Also, the bushings in the rear control arms also wear out over time causing uneven ride height and loss of traction.
If these parts have never been replaced on your car I recommend replacing them all.
You'll be amazed at how nice it will look and ride.
