89 Mustang GT, Procharger, 331 Stroker, 407whp/417wtq
Discussion in 'MW Classifieds' started by ATISTANG, Aug 10, 2009.
  1. ATISTANG Member
    Apr 15, 2006
    Message Count:
    107
    Asking $10,000 OBO
    1989 Ford Mustang GT 25th Anniversary Edition
    96k miles on body, about 2-3k miles on engine and trans
    Clean Title
    List of Mods;
    331 Stroker, Pro Bullet Level 20 block by DSS, Forged Pistons and Rods, Steal Crank, Anderson B41 cam, 1.6 aluminum roller rockers, Trick Flow TW Track Heat Heads (2.02 intake, 1.60 exhaust valves), Trick Flow Street Heat upper and lower intake manifold, BBK 70mm Throttle body, 50lb injectors, Moroso 7.5qt oil pan, DSS main girdle and windage tray. ARP rod bolts, ARP head and main studs
    ATI ProCharger P1SC @ 8 PSI
    Mac 1 3/4" primary to 3" collector Long Tubes, Mac 3" Pro Chamber, Mac 3" Pro Dumps
    MSD 6BTM ignition box, MSD Coil, MSD Pro Billet Distributor
    Tremec TKO600 Transmission (5spd)
    Spec Stage 3 clutch (6 puck), Spec Aluminum Flywheel
    UPR Triple Clutch Quadrant and firewall adjuster
    Trick flow 10.4mm Plug Wires
    3.5" (~90mm) ProTube MAF (Mass Air)
    Mac upper and lower rear control arms
    Ford Racing Aluminum Drive Shaft, Ford Racing 3:55 Gear
    BBK lowering Springs, Monroe Shocks
    Fal Black Magic electric fan
    Ron Davis 2 row (1"thick rows) Aluminum radiator
    Anderson Power Pipe
    1/0 Power and Ground cables, battery mounted in hatch, Flaming River battery disconnect
    16" Chrome Pony wheels
    Saleen Spoiler
    Cervinis rear bumper
    Auto Meter Boost, Fuel Pressure, Coolant Temp, and 5"in tach with shift light
    Car made 407 horse power and 417 ft/lb of torque to the wheels on 93 octane gas tuned by Pauls Automotive. This is a conservative tune, basically its a little rich with a little less timing then they would normally run. Easy potential for 500 to the wheels with a pulley upgrade and retune. I've taken it down the 1/4 mile twice on the street tires on it now. I had horrible 60ft times due to obivous traction issues without the proper tire. 13.7 @ 114mph. I strongly believe this car is capable of a low 12 high 11 with good drag radials.
    I have receipts for most of the stuff listed, including the engine and trans. I also have some of the stock parts, including the stock wheels with good tires(low tread but still usable) Serious buyers only please. I might be open to offers but NO TRADES.
    over 20k invested
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
Share This Page
