This car sounds bad a$$ Is there anyway to get a supercharged car to have the blow off sound?
http://www.youtube.com/watch?v=BWx-XeaNMaY
a BOV isn't needed for a S/C, but you can route it that way on purpose to be extra special
all depends on what type of blower you're using, the novi's come with a bov in the kit, all be it a recirculating one, but a bov none the less... you still need to ditch all the boost in the inlet pipe when you slam the throttle plate shut
Can't S/C guys not have BOV's because you can't have air exit the intake between the MAF and engine? Or something like that. Would cause you to run rich because the MAF would tell the injectors more air is coming than actually is... Hell if I know.
Or just never slam the throttle plate shut...
bwahahahahahaha
you are right on the MAF point yeah, all you have to do is make sureyou have one of the BOVs that dumps the air back in to the atmospheric side of te blower, but after the maf...
Due to altitude correction on the dyno, (it was dyno'ed at 4000+ ft above sea level) those #s are inflated. It's more like 700+rwhp. Still a badass car, though.
