:SNSign: Okay folks, after 4 years of following this forum, I'm finally joining and entering my first post. I'm am active duty member in the US Coast Guard , and I've been (patiently) dealing with an overheating issue for the past 4 years that has dogged me from Puerto Rico to Virginia to Alaska and now to St. Louis. Please bear with the following long explanation, but I feel that it's very important to offer some history.
1. PUERTO RICO: Car began overheating after install of Steeda U/D pulleys, GT40P heads, Precision Products 75mm TB, Crane 1.7 RR and Ford E-303 cam by Puerto Rican mustang speed shop in January ‘03. EGR capped, emissions hoses removed. Thermostat removed due to immediate overheating. Ran okay for a few months, then began running very hot. Discovered fan wasn’t operating correctly…not coming on at all. Fan motor (HI/LO) tested out fine. Replaced water pump, TPS, brake booster, master cylinder, battery, MAF with C&L 76mm MAF system; and added 24 lb injectors, Accufab adjustable fuel pressure regulator, and installed Fluidyne radiator. Shipped car to Virginia.
2. VIRGINIA: In March ’04, car “diagnosed” with a blown head gasket by a reputable Mustang speed shop in Norfolk VA, so tired engine was ultimately replaced with a fresh 306, ported/polished Typhoon U/L intake, PI Stallion 2800 stall converter, custom subframes and a 180 stat. Still ran hot. ECT connector unplugged by speed shop in order to force (HI/LO???) fan to run all the time. Fan does not come on with ECT connector plugged in, so plug connector was (and still is) left disconnected. Oil pressure reads very high, and it occasionally pegs the gauge, but car didn’t overheat. Drove x-country from Virginia Beach, VA to Bellingham, WA, and had to run with the heater on to keep the car from overheating at highway speeds in August ’04.
3. ALASKA: Installed 160 degree stat (’05)...although I hear this isn't a good stat for a 5.0Ldue how cool it runs, replaced alternator (’05), ECT (May ’06) and CCRM (May ’06). ECT connector voltage measurement was fine, and ECT sensor checked out fine. Car ran very cool (“O” in NORMAL) most of the time. Then, in April ’06, car ran hot and overheating. Ford Dealer diagnosed problem and found leaking “manifold(???)” by a/c compressor; dealer that said that the ECT was bad and that the fan AND compressor will not work if A/C system is discharged…??? $400 later, they replaced the ECT and charged the A/C system. A/C blew cold. They also recommend replacing the leaking “manifold” for another couple hundred bucks. Shipped car to St. Louis with intentions of getting a second opinion.
4. ST. LOUIS: Car overheated when picked up from military VPC (August ’06). Fan wasn’t spinning. Fan worked better the next day and for the next couple of weeks. A/C blowing hot air, so added refrigerant to the system and drove car 100 miles round trip to friend’s house. Had to run heater to keep car from overheating, but fans was running.
Car suddenly started running hot and overheating a few weeks later (couple of days ago); no refrigerant in the system and fan not running. Tried to recharge, but leaking at HI pressure AND LO pressure Schrader valves! Jumpered the LPS connector to run the A/C compressor while charging the A/C system: no joy. Verified that when ECT connector is plugged in, fan runs for a few moments, then cuts off.
5. Really not to worried about the A/C, but will test voltage at LPS connector and A/C compressor connector; and will also install valves when I get access to a meter and some tools. The main thing is the fan.
I’ve been following this forum for over 3 years seeing what others are doing to combat similar issues. Thanks to Hissin5.0, I’m seriously considering running the DC Controller so that I don’t have to worry about a switch to run the fan on high. http://www.dccontrol.com/
6. My questions are:
(1) why does the fan run for about 15-20 seconds, then stop when I plug in the ECT connector, even with the A/C system charged?
(2) does the A/C system have to be properly charged in order for the A/C compressor to run when the LPS connector is jumpered? In my case, I used a paper clip to loop the 2 contacts in the connector.
(3) was the Ford dealer in Alaska correct when he stated that the fan and A/C compressor will not work if the A/C system is not charged? If so, what’s up with the so-called A/C delete kit? Wouldn’t deleting the A/C system cause the fan NOT to work?
(4) Does the LO fan or HI fan run when the ECT connector is disconnected? I'm hoping the answer is the LO fan, which would explain why the car runs hot while I'm cruising on the higher, forcing me to run the heater to help dissipate some heat.
I am now at my wits end. I am definitely a poster child for dumping way too much money into chasing this problem. I will appreciate any and all observations and advice.
