Not too sure about the 97 cobra, but I had a 98 and now own a 96 and I haven't had any major problems. You can go to
www.scoa.org or
www.svtoa.com
One of the two has recall information on every year cobra.
On the old '98 I had, either the AIT sensor (Air Intake Temperature) or the MAP (Manifold Ambient Pressure) sensor went bad, but was fixed under warranty. It wouldn't be that hard to fix if I had to do it myself.
My '96 does just fine for me. They have the potential to handle very well if you add subframe connnectors, good shocks and correct spring rates, and roll bar rates for aftermarket stuff. Don't skimp out on aftermarket parts and just do it right the first time, b/c after all it is a Cobra.
As far as late-model GTs go, the aftermarket might be more developed for that generation of late-model stangs, but the 4-valve head is going to make more power and especially in the upper RPMs. Also, the motor of the earlier Cobra is better equipped for power adders, 'cause it'll have 6-bolt main caps instead of 4 or 2, the crankshaft is forged steel and will easily handle 1000+ HP, the only thing you have to worry about if you are concerned with big power is, the oil pump gears, bigger volume oil pan, main stud girdle, better rods, pistons, and rings. The valvetrain on a 97 SVT is suited to go up to 7000 RPM stock. It is worth the money to get the SVT, especially if it is that generation b/c the price difference is nearly negligible when that old. Also, the 96-98 Cobra block is probably the best one made yet. SHM claims that this block (made in Teskid, Italy) will handle 1500 HP when it is properly prepped and it is reinforced with items such as a main stud girdle, ARP head, rod, and main bolts. Not too shabby. Sorry I'm talking my @$$ off about Cobras again, but I would go with SVT muscle. You'll see bigger gains out of it
Take care and enjoy.
