9mm plug wires
Discussion in 'Mustang II' started by Gunmetal5oh, Jul 9, 2004.
  1. Gunmetal5oh Founding Member
    Apr 11, 2002
    Message Count:
    1,095
    36
    I have a brand new set of 8mm plug wires I planned on installing tomorrow. Unfortunately I found out I can get a set of 9mm for the same price even though they told me they were "a lot more" when I asked for them originally (at O'Reilly Auto). These are Borg Warner Select #CH859 SuperMag wires.
    Is it really worth having 9mm wires?
    I can take these back and pick up a set of 9mm Ford Motorsport wires for no extra cost.
    Lower resistance.. easier on ignition components, more consistent spark?
    Worth the gas money to do the exchange?
  2. Gunmetal5oh Founding Member
    Apr 11, 2002
    Message Count:
    1,095
    36
    I thought I should add, I searched the web for a comparison between the two but couldn't find any info. From all the advertising hype for 9mm wires I figured there would be some evidence of improvement. :shrug:
  3. THE COBRAMAN pig 'rassler
    Mar 11, 1999
    Message Count:
    1,994
    9mm wires...the fart cans of ignition components.
    Given the same conductors, there really isn't any difference, other than the extra mm of insulation/jacket. Which may or may not be beneficial, depending on what it's made of.
  4. Wart I'm Mad as HELL and I'M not Gonna Take it ANYMORE!
    Sep 1, 1998
    Message Count:
    3,126
    I thought that honor went to transparent distributor caps. Or was it neon boots?
  5. 85MustGT Founding Member
    Nov 8, 2001
    Message Count:
    339
    I love the transparent dist cap! :rlaugh:
  6. COBRAIIW New Member
    Apr 26, 2003
    Message Count:
    598
    keep the 8mm.
  7. Dano78 Founding Member
    Nov 1, 1999
    Message Count:
    2,662
    Unless you're running a lightining-power equivlent ignition system, there's no need to go ANY higher than an 8.8mm wire. On the norm I use 8mm on all my stuff when i can. Stock applications are really all 7mm is good for.
    Now to determine a good wire, size is hardly as importand as the actual construction of the wire itself. Grab a MSD or Accel Catalog and flip to the back and read all the Tech articles that explain all the different types. You'll get thte gist of what's good and what's not and what will work best for your application. :nice:
  8. zwhitr Founding Member
    Aug 27, 2001
    Message Count:
    851
    what about the cap that puts all your left side wires on the left and all your right side wires on the right
Share This Page
