Aftercooler with Mondo Bypass Valve?
Discussion in 'Fox 5.0 Tuning' started by ptb302, Nov 20, 2009.
  1. ptb302 New Member
    Nov 20, 2009
    Message Count:
    I dont know if this was a smart move or not..I picked up a Aftercooler with a Mondo bypass valve weld on it.
    And im using a S-trim with the basic pulley setup..
    but im sure I got to have more boost to use this setup.
    What should I do? Keep it ..or Sell it? Thanks guys!
  2. ddonaca351 Active Member
    Dec 1, 2002
    Message Count:
    2,072
    46
    Well the bypass/blow-off valve won't hurt anything if you're not using it... it'll just sit there.
    You can however get a more..., um..., "turbo-like" (making up my own terms for lack of a better one) performance from a centrifical by using a bov. Basically you drop the pulley size, to up the boost level at redline and then set the bov to open up at you're original desired boost level. So you wind up getting to 10lbs (arbitrary amount for example sake) sooner in the rpm range, then once there the bov vents the excess off from that point up till redline.
    But you can just use the aftercooler as is if you like, and just have the bov as a added safety feature or something...
    Either way should work.
    :nice:
  3. 600hp88notch New Member
    Dec 15, 2009
    Message Count:
    BOV is fine, dont use the aftercooler, they suck. I have no intercooler or anything on mine and makes a ton of trq. and power at 13 lbs boost,basically the same blower u have
  4. ptb302 New Member
    Nov 20, 2009
    Message Count:
Share This Page
