air shocks, what are they used for?
Discussion in '2.3L Mustang Talk' started by andrw, Jan 23, 2004.
  1. andrw New Member
    Feb 1, 2003
    Message Count:
    384
    i saw a pair on ebay, air shocks. just curious what they're used for? not the gay lowering/raising is it?
  2. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    Air shocks are supposed to be used to increase load capacity, but some people do use them for raising and lowering the back of their vehicle (redneck style right there)
  3. Cougar Founding Member
    Sep 29, 2001
    Message Count:
    917
  4. andrw New Member
    Feb 1, 2003
    Message Count:
    384
    i thought they were for load. i was actually considering them because i have a part time delivering papers in the morning, and right now i have a couple of spacers in the springs in the back.
    i guess thatll do for now. thanks for the quick response :)
  5. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,753
    78
    They allow you to basically adjust the right height and 'spring rate'. The higher the pressure, the stiffer the suspension. If you have a heavy load, you increase the pressure to carry it safely, and without bottoming out the back end.
    Drag racers love them because it allows them to lower the pressure for better weight transfer. Then, they can jump back on the street and suffer no ill effects of a drag racing suspension.
    They are also used extensively by ricers and show cars to dramatically change the ride height. Kinda dumb, because unless you have a solid axle, changing the ride hieght destroys the alignment.
  6. Red_LX Doubt I could be of much help, unless you need por
    Aug 21, 1998
    Message Count:
    10,471
    78
    Sounds to me like you're thinking of air bags, not air shocks. Two very different things there.
    Drag racers usually use air bags as well. Usually they put one inside the passenger side spring, so that when they pressurize the air bag the car won't twist toward that side as much and it helps both tires maintain equal traction.
  7. 351wcoupe New Member
    Feb 13, 2003
    Message Count:
    1,845
    thats what I would say.
    I used that inflatable system in the 351w and it works great.
  8. bhuff30 Founding Member
    Dec 11, 2001
    Message Count:
    5,753
    78
    I thought a shock by nature was a tube filled with compressed gas?
    But yes, I am thinking of air bags I guess.
  9. andrw New Member
    Feb 1, 2003
    Message Count:
    384
    my lincoln has air bags, if those are similiar, theyre nice for a smooth ride...but suck when they go. maybe 10 years ago i paid over $1000 to have them replaced.
    now theyre $30 on ebay.
  10. Dan'l Founding Member
    Aug 2, 2001
    Message Count:
    1,540
    Get a set of moog cargo coils-a good compromise between load and handling. Problem with air shocks to increase payload capacity is if they blow out or loose a line while under load, there you sit with your fenders on the tires.
Share This Page
