Went to VeryUseful.com to check an airbag code Im throwing right now...3 flashes, pause, 2 flashes. According to info, it is a very common problem:
Prolog:
Error code 32 is the most common air bag problem. Chances are Very Good that you have bad clock spring in the steering column. It is Very Easy to replace! Get a NEW one from Ford. They are not very expensive (between ?$45 to $90?). Do NOT waste your time or money getting a used one from the junk yard that may break soon. The clock spring connects the turning steering wheel to your stationary steering column. So, over time, they have a tendency to break
At first I thought the problem was that I had my 2 front sensors off, because I threw codes before when they were off. I used the jumper method described to clear the codes.
Since I had the sensors off for the rebuild, I assumed my codes were for that before reading what 32 actually meant. So when I tried to jump the box and clear them it didnt work.
MAIN QUESTION: Is the 3 flashes, pause, 2 flashes code 32 and is what is described on the site the ONLY possible cause and solution to this?
Thanks
RC
Prolog:
Thanks
RC
