F FoxTail Member Jan 2, 2011 35 0 6 Central Illinois Jan 19, 2011 #1 Jan 19, 2011 #1 E-303 Cobra Intake 70 mm TB 65mm C&L MAF 24lb Injectors BBK fendermount Crane Cams Fireball 6 Ignition Edelbrock 1.7 Performer Heads Long Tubes 3.73 T5 WC No bore, Stock Bottom What cam would you replace the E with to get more power? Its a weekend driver. Emissions don't matter.
Cobra1741 Member Mar 9, 2010 152 1 16 Jan 19, 2011 #2 Jan 19, 2011 #2 i literally just bought a new cam to replace my e303. LSA - 112 degrees Int dur. @ .050 - 218* Exh dur. @ .050 - 228* Int Max Lift - .542" Exh Max Lift - .543" with 1.7rr 50* of overlap at .004"
