Another TSB
Discussion in '2005 - 2014 Specific V6 Tech' started by ForeverFord, Jun 30, 2005.
  1. Let you guys know more when its done, My tank is ordered[TSB] my stereo[TSB] and the one I did not know about upper strut bearing[TSB]. When I took it in to get the tank and stereo coming the dealer told me about the bearing because told them to check out the very small guiet clunk in the front end. I just switched from a svt 2004 focus to my mustang and the mustang has a tinny sounding body on it,[like when i slap a wet chamois on the roof or hood so I was unsure if I was just hearing tire noise thru the body or what.Has anybody else hear of this? I have never heard of a upper strut BEARING before. Strut bushing yes or mount but bearing?
  2. old news. here is the tsb but thanks
  3. thanks afixer my pony is just 3 weeks old to me hopefully i'm caught up.
  4. here is the list of TSB's
    Technical Service Bulletins
    2005 MUSTANG - US (English)
    05-14-4 ( this one is new)
    WRENCH LIGHT ON WITH BOTH DTC P2106 AND P2135 - VEHICLES BUILT 11/29/2004 AND PRIOR
    05-10-19
    INTERMITTENT CD PLAYER CONCERNS - AUDIO UNIT PROGRAMMABLE MODULE INSTALLATION (PMI) REQUIREMENTS
    05-9-18
    DISCHARGED BATTERY - CHARGING SERVICE TIPS
    05-9-14
    CONVERTIBLE TOP RAISE/LOWER INSTRUCTIONS
    05-9-11
    FRONT SUSPENSION POPPING NOISE WHILE TURNING RIGHT OR LEFT - VEHICLES BUILT BEFORE 4/8/2005
    05-9-3
    INTERIOR PLASTIC TRIM - PAINT-TO-MATCH AND REPAIR - INTERIOR SPRAY PAINT AND ADHESION PROMOTER USAGE INSTRUCTIONS
    05-8-8
    GROWL/GRINDING NOISE IN 2ND OR 3RD GEAR DURING DECELERATION - TR3650 MANUAL TRANSMISSION - VEHICLES BUILT BEFORE 1/15/2005
    05-8-6
    EXHAUST VIBRATION AT 850 RPM - 4.0L ENGINE AND AUTOMATIC TRANSMISSION
    05-7-3
    AXLE WHINE - VEHICLES BUILT THROUGH 11/15/2004
    05-6-15
    AIR BAG WARNING LAMP ON - DTC B1891 IN RESTRAINTS CONTROL MODULE OR LAMP FLASHES CODE 53 - VEHICLES BUILT BEFORE 10/02/2004
    05-4-8
    FUEL FILL SLOW, OR DIFFICULT TO FILL
    05-3-1
    MAF DIAGNOSTIC SERVICE TIP - VEHICLES EQUIPPED WITH EGR SYSTEM MODULE (ESM)
    04-26-22
    MALFUNCTION INDICATOR LAMP (MIL) ILLUMINATED WITH MULTIPLE DIAGNOSTIC TROUBLE CODES (DTCS) P035X AND NO DRIVEABILITY SYMPTOMS - 4.6L 3V ENGINE
    04-26-16
    WELD BONDING PROCEDURE
    04-24-20
    LIMITED SLIP AXLE CHATTER, SHUDDER, BINDING SENSATION, OR VIBRATION DURING LOW SPEED TURNING MANEUVERS
    04-24-14
    GENERAL PCM PROGRAMMING PROCEDURES
    04-24-5
    REAR WINDOW DEFROSTER GRID/INTEGRAL ANTENNA DIAGNOSIS AND REPAIR - TERMINAL TAB REPAIR
    04-16-1
    ENGINE MISFIRE OR ROUGH RUNNING - COIL ON PLUG (COP) IGNITION SYSTEMS - WDS COP KIT DIAGNOSTIC TIPS
    04-14-7
    SERVICE WIRING HARNESS REPLACEMENT GUIDELINES - SERVICE TIPS
    04-9-6
    BODY - PAINT - IRON PARTICLE REMOVAL - INDUSTRIAL FALLOUT - ACID RAIN NEUTRALIZATION
    ________________
    TSBs found:20
    © Copyright 2002-2005 Ford Motor Company. All rights reserved Privacy • Contact Us
  5. Looks like I have the axle whine and the exh. vibration too, what do they do for those new axle and exhaust?
