It poured here in Miami for two hours. When I got into the car it smelled really bad and was wet on the drivers floor board near the lower left corner of the floor mat. Anyone else have this problem???
I may have a solution to your problem.My trunk is a swimming pool
I got water near the fuel pump relays in trunk
lot of moisture coming up to rear window
a big mess
still not able to find where it comes in , but it seems worse when moving under heavy rain : I read all f***ing threads and tsb here and on bradbarnett on leak matter but found no advice on mine .
As soon as it rains again I have to check it better ... once again
Luckyly Italy has often good weather , at least
Mine leaks as well.............only with really hard and big rain volume....mine is on the pass. side...........seems like water comes from in behind the glove box and pools there. Once I get going, the inertia from going forward and turning left 2 right makes it just pi$$ out.
Water was getting into my Stang's trunk, even after the dealer resealed a leaking rear window. It was filling a trough in the bottom of the driver's side rear quarter panel behind the interior trunk cover. After the water filled up that area it spilled over, and flowed under the trunk carpet into the spare tire well. I also noticed that dirt and grit was laying in the bottom of the water in both areas, which told me that it was splashing up into the trunk from underneath the car when it was moving on wet roads.
I dried out both wet areas, cleaned out the drit and grit, jacked up the rear driver's side of the car, removed the wheel, sprayed the entire wheel area with high pressure water from a hose, and checked the trunk for water. None. I then sprayed behind the wheel area along the underside of the quarter panel, and water appeared in the quarter panel trough inside the trunk.
The source of the leak turned out to be a poorly sealed area on the underside of the quarter panel where the gas fill tube passed through it. I resealed this area with duct seal, dried out the quarter panel trough inside the trunk, and resprayed. No water showed up in the trough, and it and the spare tire well have both remained bone dry since then.
You're welcome. Good luck on finding the leak source.Wow ! thanks for the advice !!
Mine seems to leak on the passenger side , when I drive in heavy rain .
When the car is sitting under same heavy rain I have no leaks , so it must be linked to movement/tyres etc : I'll inspect the tyrewells and grommets .
Good point to remove the wheel
Thanks again
Steel
