Anyone know the problem?
Discussion in 'Fox 5.0 Mustang Tech' started by 1qckFOX, Jan 5, 2004.
  1. My car's burned more than 3 quarts of oil and ive not even drove it 300 miles. No smoking of anything. :shrug:
  2. Is it leaking anywhere.
    Maybe its not leaking when the car is sitting. But it may leak when its running and a load is on the motor.
    Check for leaks
  3. Does the lower intake have the baffle plate under the hole for the PCV valve and screen? If not you will use a quart of oil every 2 or 3 days.
  4. how many miles? could have bad oil pan seal's maybe crank shaft? can you see any signs of heavy oil stains?
  5. No sign of leak sitting but havent checked in motion. 35k miles, and im not ure about the lower intake baffle plate but i will check all of these soon. Thanks for the advice.
