I know there isn't anything to be gained powerwise. I was just thinking that if the swap could've be done fairly easy, It may have been a possible alternative/fix concerning the 2 piece spark plug issues.
But after you pointed out, that it would also require changing the timing cover, timing chains & gears, water pump, intake manifold and TB. Not to mention having to re-tune your PCM, because you'll no longer have variable valve timing, but instead would now be running a four cam setup.
Therefore It's obviously way too expensive, and just isn't worth the hassle.
In the meantime, I'll just wait until Ford comes out with a new one piece plug design.
