- May 9, 2005
- 189
- 0
- 0
Hey guys,
I've been hearing a ticking/knocking sound coming from the bottom end of my engine.
Just today I finished removing the kmember and oil pan to check the carnage.
I suspected a spun rod bearing.
I removed 3 rod caps.
The rod bearing on the first rod cap I removed came out separate.
It seemed to be clinging to the crankshaft.
I pushed the piston up the bore to get to the other bearing and it was also no longer attached to the rod.
The other two caps still have their bearings firmly attached.
The two bearings from the one rod are badly scratched and scarred on the side where the bearing meets the crankshaft. So basically both bearings were spun?
Pieces of metal (metal shavings) appear to be peeling off the bearings.
Some of these shavings were also found in the oil pan (but not many).
I checked the crankshaft journal where the bad bearings were. It did not looked to be scratched at all.
Is this a spun bearing? Even if the bearings are so scratched and the crankshaft has no damage what so ever?
Attached are pictures of the bearings.
What do you guys think?
Thanks,
Patrick
Thanks,
Patrick
