I was just wondering if anyone out there knows the best way to set our cars up for auto cross. What would be the best suspension kit to buy. I also want to know what kind of rims and tire combo would be the best for just on the track.
ClayStang - I think you're fine with the Watts link far as I read the rules. Those tires are good to learn on, down the road you're going to want to step up to something bigger and a real R-compound tire (like a Hoosier A6 or Kuhmo V710).
Walter - I think I've seen your car out there before. I'm in the yellow / orange / red CP Camaro. Missed the event today due to being jet lagged from work, but I make all the other ones!
Bullitt, Could I stay in ESP if I had Watts Link instead of a panhard bar. The suspension setup i am looking at the steeda club racer stage one and a techco watts link. The tires i would run would be 245/45ZR17 Nitto NT01 on the stock 17 inch rims.
I'd be suprised if you could stay ESP ...
you can't even replace the lower control arms.
Regarding the above: 15.8.I
1. Addition or replacement of suspension stabilizers (linkage
connecting the axle housing or De Dion to the chassis, which
controls lateral suspension location) is permitted.
Based on 1) I take that as you can install a Watts, but I'm not an ESP expert. The control arm bit is covered by 5).
ClayStang - it sounds like you want to autocross, but don't want to build a dedicated autocross car. In that case I'd build it within SM rules as you get a lot more freedom and can add the power you want for the drag strip.
