302 coupe said:I was with you before you even knew it....
Sounded like you got lost there for a while. Let me know if I can be of further assistance.
notny41 said:I'm not at the car right now, but I had been monkeying with the choke also, so I probably have that all F'd up by now too. It is a an automatic choke (driven by a thermo-spring) and I had it apart because it never seemed to fully close off when your first start the car - maybe it isn't supposed to. But in my efforts to try to get it to fully close I turned screws and cranked the cover almost all of the way to the rich side.
So, do I start with trying to get the choke dialed in correctly, or do I start with timing, or do I start with idle mixture screws? It is never going to get driven in really cold weather so if I can get by without the choke, that is just one less thing for me to feel like I screwed up.
Let me also say that this was a two barrel carb at one time and the previous owner threw on the 4100 and the 4 v intake and spacer. Don't know if that is important info here or not.
notny41 said:Well, I confirmed it. I crawled under the front end with a flashlight and the passenger side motor mount rubber has a big diagonal crack in it and even I can tell it is in need of replacing.
Didn't mean to hyjack a carb thread with motor mount stuff, but could this possibly be giving me idle and symptoms of running rough while going down the road?
