I installed an Autometer Lunar Trans Temp Gauge. The gauge works fine but my issue is with the lighting. I tapped a wire (brown in my 03) that when the light switch is pulled to park the gauge lights up but had no dimming control on the AM gauge. So I tapped the dimmer light wire (BL/WT) to the same wire I tapped for the lights and lost my dimming control to my cluster and everything else. When I removed the tapped (BL/WT) wire my dimming control returned. Q: Do I have to tap straight to the dimmer wire from the AM gauge wire for the dimming to work?
