Bad AC Compressor ?
danny04GT
50
Phoenix
I can see that the pully for my A/C is spinning slower than the belt. This is causing my A/C to not work. It seems to do this intermittantly and after I have been driving for a long time. The slipping is causing the belt to burn and smoke while the car is running. Even when the A/C is off I can hear a chccck, chccck, chccck noise (thats the best i can describe it) as the car is idling.
I assume there is some type of bearing that is frozen in the compressor. Should I replace the entire A/C compressor with the clutch? Or would there be another part that could be services without changing the entire compressor/clutch ?
It is more than likely just the clutch, take it off and see how freely just the compressor spins. Hopefully it isn't the compressor. The clutch assembly can be bought for around $50 at autozone. I replaced mine with one form autozone over three years ago with no problems so far.
Thanks Guys! I appreciate the help. It looks like autozone has just the AC clutch for $135, they have a rebouild compressor with the clutch in stock for $159 though. should I buy the whole thing? Or will it end up costing alot more cause I will have to refill the freon?
Man up?? Im in Phoenix, it wont be under 100 during the day for about 3 months. It hit 113 last week. I doubt you have the same issue in Jersey. Besides, the whole thing with pully not spinning while the belt is, might be a problem...
I can't really say how much more work it would be to swap the whole thing. I'd rather not have to fool with draning the system and flushing it to put the new compressor on.
