- May 28, 2011
- 15
- 0
- 1
I am coming to you guys again. I did a search and found alot of mixed info but nothing really anwsered my question.
I am going over the car I just bought. 1992 5.0 5spd Coupe SSP. I am fixing all the "little" things. Looked under the hood and discovered the BAP sensor is mising. Connector is there, but no sensor. Not sure if they left it off from when the car was painted or what. The car has an E-cam if that matters. The engine is otherwise stock. Seems to run fine. At times it has long crank and sometimes on slow speed/rpm turns it will shut off , but starts right back up. Not sure if that is related.
Thanks in advance. you all are alot of help!
