- Sep 28, 2004
- 72
- 0
- 6
what would be a good cost effective 347 h/c/i combo that will get me about 325rwhp on a mustang dyno for about $2000-$2500? i was wondering if the trickflow kit would get me close, i know the heads are a little small but the kit is well thought out and works good from what i hear. i know anderson makes a kit with patriot heads, a typhoon intake, and an anderson n51h cam i think, and holley makes the systemax kit which i hear mixed reactions about but once again i think is 302 based, and all the edelbrock kits i see are for carbed motors, but i noticed there are model numbers for the efi parts like the rpm intake, with rpm heads, and one of their cams, i thought that the rpm xt with the rpm intake and a comp cams cam would work well, but you're looking at some cash there. i've also considered afr 185 heads, a comp cams off shelf and the trick flow track heat. any input??
i have a 347 with flat top pistons now and cast iron roush 200's and a anderson cam, not working good so i want a proven combo.
