Build an 8.8 axle or swap in a 9 inch
Discussion in '94-95 Talk' started by BLOWN347STROKER, Oct 9, 2009.
  1. BLOWN347STROKER Member
    Jan 13, 2009
    Message Count:
    237
    topeka kansas
    I am having some issues on this topic and was wondering what everyone thought. I have a stock 8.8 axle under my car. With the current setup I have I have already snapped a stock axle shaft off. I just put another stock one in the rearend for now because i already had one. I was just wondering what you guys thought would be the best route to go. Should I build up my 8.8 with tube braces, axles, and spool or should I just switch to a 9 inch and build one of those.
  2. final5-0 Mustang Master
    Apr 7, 2003
    Message Count:
    6,808
    78
    DFW Texas
    9" is stout for sure :nice:
    Then again ... it weighs more than the 8.8 :(
    Nice thing about the 9" is you can quickly swap out the punkin
    and you got a different ratio ;)
    Another thing about going 9" is you will have to deal with
    modifying it or buying one already setup to fit your Stang :(
    I gotta tell ya ..... Them 9 inchers are tough :Word:
    I used to do full on launches at strips all stuck up with VHT
    at 5 to 6K with wrinkle wall slicks and never broke nuthin :)
    Grady
  3. BLOWN347STROKER Member
    Jan 13, 2009
    Message Count:
    237
    topeka kansas
    were using a built 8.8 or a 9 inch for that.
  4. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    You can run an 8 second quarter mile on a properly setup 8.8. The 9" has a lot more parasitic drag, and is going to slow you down. Definately go with an 8.8.
    Kurt
  5. GTA_V6_Mustang Active Member
    Nov 29, 2004
    Message Count:
    1,299
    36
    Miami, FL
    I second that, Just build the 8.8. Weld the tubes get a good diff with some axles and your good.
  6. revhead347 I have face herpes.
    Jun 14, 2004
    Message Count:
    4,672
    68
    Acworth, GA
    And an axle girdle is a good investment too. They aren't that expensive.
    Kurt
  7. BLOWN347STROKER Member
    Jan 13, 2009
    Message Count:
    237
    topeka kansas
    Thanks for the input guys. I am going to stick with my 8.8
  8. ProKiller Founding Member
    Apr 26, 2002
    Message Count:
    2,941
    58
    PA
    in the end i think the 8.8 would be cheaper too
Share This Page
