- May 23, 2006
- 1,095
- 2
- 36
94-95 Mustang SVT Cobra C&L 76mm MAF Mass Air Intake
76mm - 94-95 GT (19 lb) or Cobra (24 lb) & inlet pipe
Part Number: 118
Owners of the '94-'95 V8 Mustang and Cobra vehicles have long needed a complete intake solution to address the key problem areas in the factory plastic air meter and filter assembly. By eliminating everything from the throttle body forward, this new system has been dyno proven to increase horsepower by as much as 18 over stock and as much as 12HP on vehicles equipped with complete K&N replacement systems.
This package includes the C&L inlet assembly, specially calibrated 76mm MAF unit, filter assembly, plastic heat shield and all the necessary fittings for assembly. The inlet tube is designed for use with intake manifolds that keep the stock throttle body location. If you intend on using an '89-'93 style intake manifold with adapter, you must ensure that the throttle body location is unchanged. Otherwise, minor modifications may be required for proper fit.
Condition: In great used condition! Will function just like new, Usual wear from install/removal/weather. Could use little cleaning, Comes with new filter. Don't buy new buy these! Retails for $300.
Includes: 94-95 Intake pipe, 76mm MAF, New filter, Heat shield.
$250 OBO + $20 shipping, Boxed, Ready to go.
Part Number: 118
