Ok guys i got a 331 sportsman block with a main girdle forged internals set for a 8.8 compression with a v2-sq trim set for 12 psi as of right now... I need a good blower cam and I called up Comp Cam and they gave me these specs for the right cam for my car, but its an off the shelf cam..
part # NX274HR-14 specs 224/236 .555/.570 114
This is going to be a daily driver car, but a track car as well.. Anderson said that his B31 cam is perfect for my car, so i dont know what to do??? I talked to my engine builders and they said to go with anderson cams, but i want know other opinions before i buy the cam and install it... Let me knoww what you guys think or what you guys would do..
Also i have 185 AFR heads with upgraded springs to help prevent valvle float, bbk long tube headers, stock computer with 373 gears... If you guys need more info then let me know.. Thank you and hope yall have a nice a holiday !!!
