I recently bought a 302 long block from a buddy he had not long put it together and lost his job.Its a stock 92 5.0 with new crank,rods, pistons, the heads are also stock other than 3 angle valve job,new valves and seals.I have factory intakes upper and lower as well as injectors. I do have mac cold air and 2.5 exhaust with h pipe and no cats.also i have 3.55 gears what cams can i run and not have valve to piston clearance problems.Iwant something that sounds good but not to radical this is my daily driver.Im kinda interested in B,E,or,F cams Ijust dont know. Thanks for any help you folks offer.
