I need some help choosing a cam. I have a 67 Mercury Cougar XR7 with a 289and C4 automatic. I'm wanting to install a roller cam and am not sure which cam to use. This will be a fully functional street car with A/C and all the modern comforts I can cram into it. I want to really wake up the little 289 and make it scream, but still have great street manners and hopefully some respectable gas mileage.
I realize that I'll have to purchase a retro-fit cam, but for now I'm looking at cam grind numbers. It currently has an Edelbrock Performer 289 intake manifold, which is rated from idle to 5500 rpm, so I need to choose a cam that will work well off idle. I'd really like a cam that would make awesome power from idle clear up to about 6200 to 6500 rpm, if that's possible. The cams I've been looking at are: Ford Motorsport X303, (advertised power range is from idle to 6200), Ford Motorsport Z303 (advertised power range is from idle to 6500), Edelbrock #2221 (advertised power range is from 1500 to 6500), Comp Cams #35-349-8 (advertized power range from 1500 to 5500), Comp Cams #35-514-8 (advertised power range from 1600 to 5600), Comp Cams #35-351-8 (advertised power range from 1800 to 5800).
Has anyone used any of these cams I mentioned? What is your opinion? How do they perform with my combination? Are there any other cams I haven't mentioned that you have used that would work well with what I have? Thanks in advance for your suggestions....
