Can't Get Head off! Quick..Help!
Discussion in 'Fox 5.0 Mustang Tech' started by TheUser, Dec 21, 2003.
  1. trying to get pass. side head off and it won't budge. I pulled the header off and i've tried to pry it (I was careful) between the lower intake and edge of head. I have a powerdyne s/c, so the bracket is in front of the head...try to pry between those as well. I tried to hit what little edge of the head that's exposed on the side of the bracket w/ a piece of wood and hammer, but that had no effect. Any quick Ideas or suggestions? :shrug:
    If i can't figure it out soon, i guess that s/c bracket will have to come off, but i'd really like to leave as much in tact as possible.
  2. You have removed the lower intake right? sounds like you havent by that statement
  3. No, I haven't. The manual says that under "both cyclinder heads," so I figured that's only if you're removing both of them. I guess that was just wishful thinking....now I feel like a moron. So I guess the intake has to come off....Thanks for pointing that out!
  4. Yeah get that lower intake off and it might help :D
    Good Luck,
    David
  5. take off the lower. Make sure you removed all the bolts and if they are the originals be sure to replace them with new ones.
  6. :rlaugh: Sorry, I've done some stuff like that too, thanks for the laugh :flag:
    Just get ready, when you get the heads off they're heavy (about 50#s each). Not too heavy, but if you're leaning over much, it can make them feel like 100#s.
    When I was pulling the driver's side head for my first time, I forgot to unbolt the ground that goes to the front of the head, so I had to balance the head between one hand and the shock tower while I stretched to reach a ratchet.
  7. NO JOKE THEY WEIGH A TON!!!!!!!! ESP WHEN YOUR BY YOURSELF TRYING TO GET THEM OFF WHEN THEVE BEEN THERE FOR 100K MILES AND 15 YEARS!!!
  8. Once all the other stuff is off, they can still be right tight. I usually pad the end of a pry bar with a rag, and insert it into one of the intake ports -- then once you've got it wedged in there, give the pry bar a good smack with your hand. That usually breaks them free without prying against anything that might break.
  9. just smack it!!!!
  10. haha no **** their heavy, an it's really a pita how you have to lean over an the them off blah i put a dent on the top of my drivers fender cause i didn't have a good hold on the head an it slipped.
    I've done that with the ground wire too mine was on the back of the head though an i was pullin, i'm like WTF why can't i get this damn thing off here.
  11. mine weren't stuck on there too bad, I just jerked a lil' bit and they came off, but then again, the heads were just rebuild about 8k miles ago
  12. ah yes the one on the drivers side rear of the head,
  13. yeah make sure you take that ground wire off! and cover your fenders with something!!!
  14. Thanks for all the replies guys! I finally got the pass. side head pulled Mon morning and i'll pull the other one prob. wed. or thurs. It was pretty heavy and bending over didn't help much like many of you noted :nonono:
