car running rich rough idle any help bout bald headed?
Discussion in 'Fox 5.0 Tuning' started by sleepys350, Oct 11, 2008.
  1. sleepys350 New Member
    Oct 11, 2008
    Message Count:
    got a 1992 mustang 302 vic jr heads corbra intake custom grind comp cam. stock maf 19# injectors a9l computer. washing down #1 plug. checked all ignition. pops through intake sometimes. gas in upper intake. rough idle. tps has 5 volt in and out. changed computer to another a9l no different. runs great at times like a turd at others. any help before i go to carb?
  2. vristang Advanced Member
    Mar 31, 2005
    Message Count:
    4,698
    66
    Seattle
    Either the tps sensor is fubar, or you're checking it wrong.
    What is the firing order of the 'custom cam'
    Pull the diagnostic codes...
  3. Kryptonite92 New Member
    Oct 12, 2008
    Message Count:
    The car sleepy mentioned above is actually mine, we are all pulling our hair out trying to figure out what the problem is. the firing order of the cam is 13726548, the tps sensor is brand new i checked both the orange wire and the green wire both have 5 volts which i know cant be rite, im gonna have the codes pulled asap. would the o2 sensors cause this? another question is, is there any difference in the computer harness from 92 to 93? the harness and comp came off a 93 gt. also runs like crap when cold after warm up its ok but after about 2-3 min of idleing the rpms instantly drop and it struggles to idle, i can shut it off and start it and it runs fine for 2-3 min then the same thing happens. My car is in excellent condition which is rare around here which is why i dont want to put a carb on it so any help is greatly apreciated.
  4. mittjere85 New Member
    Feb 21, 2007
    Message Count:
    9
    Virginia
    Posted via Mobile Device
  5. mittjere85 New Member
    Feb 21, 2007
    Message Count:
    9
    Virginia
    your tps reading should be 0.98v
  6. hotcobra03 Premier Member
    Jul 25, 2007
    Message Count:
    1,000
    38
    poteet,tx
    Have u Tryed order 15426378 .if not sure go to step 1 pull all plugs out and follow rotor feel 4 piston
  7. hotcobra03 Premier Member
    Jul 25, 2007
    Message Count:
    1,000
    38
    poteet,tx
    Also direction goes counter clockwise and tdc as you already know
  8. hotcobra03 Premier Member
    Jul 25, 2007
    Message Count:
    1,000
    38
    poteet,tx
    Tps function has nothing to do with running rich.it does power.ck codes test say ck if 68 koeo and 58,31,41 koer if yes they must be done first.
  9. Black1987Stang New Member
    Aug 23, 2004
    Message Count:
    1,457
    Jersey Shore
    kinda sounds like what mine was doing when I only had one o2 sensor or as if I had a bad one....it was basically taking the info from the bad/missing sensor and making that side of the engine run reallll lean, I had real low vacuum at idle, ran like it had a huge cam in it and it wouldn't idle on it's own. and it would be ok for a minute or two sometimes if I started I guess since it runs through the startup cycle or something. I found it out when I got my Tweecer R/t and ran it in Calcon and saw it trying to command real lean readings. I turned off the 02's by running it in open loop all the time and now it has 16.5 inches of vacuum and runs smooth like stock.
    That tps reading ain't right but if it was a tps or firing order problem I don't see why it would be running fine for those 3 minutes, it would be running crappy all the time.
    Does it run different for a while if you run it after leaving the battery disconnected for a while?
  10. FoxFiveO88 New Member
    Nov 17, 2008
    Message Count:
    9
    i had a similar problem after my MAF conversion...ended up just having to clean the build up on the plugs and adjust the timing a little....
  11. jrichker StangNet's favorite TOOL
    Mar 10, 2000
    Message Count:
    18,897
    31
    98
    Dublin GA
    Try to dump the codes. My bet is you won't be able to get them to dump.
    Dump the codes and see what the computer says is wrong…Codes may be present in the computer even if the Check Engine light isn’t on.
    Here's the link to dump the computer codes with only a jumper wire or paper clip and the check engine light, or test light or voltmeter. I’ve used it for years, and it works great. You watch the flashing test lamp or Check Engine Light and count the flashes.
    See Troublcodes.net Trouble Codes OBD & OBD2 Trouble Codes and Technical info & Tool Store. By BAT Auto Technical
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    There is a single dark brown connector with a black/orange wire. It is the 12 volt power to the under the hood light. Do not jumper it to the computer test connector. If you do, you will damage the computer.
    What to expect:
    You should get a code 11 (two single flashes in succession). This says that the computer's internal workings are OK, and that the wiring to put the computer into diagnostic mode is good. No code 11 and you have some wiring problems.
    Alternate methods:
    For those who are intimidated by all the wires & connections, see Actron® for what a typical hand scanner looks like. Normal retail price is about $30 or so at AutoZone or Wal-Mart.
    Or for a nicer scanner see EQUUS DIGITAL FORD CODE READER (3145) – It has a 3 digit LCD display so that you don’t have to count flashes or beeps.. Cost is $30.
  12. nthorpe01 New Member
    Jan 15, 2011
    Message Count:
    Be nice to know how you fixed this issue.
  13. ruststang90 New Member
    Feb 7, 2011
    Message Count:
    9
    (I turned off the 02's by running it in open loop all the time and now it has 16.5 inches of vacuum and runs smooth like stock.)
    how did u loop off o2 sensor id like to no
  14. ExTrooper New Member
    Jan 10, 2011
    Message Count:
    upstate SC
    What kind of FPR are you running? You said fuel in intake? The regulator is one of the main culprits for that right? Vaccuum line could be sucking gas into upper depending on what type of regulator?
  15. G8R302 New Member
    Oct 27, 2011
    Message Count:
    I'm having the EXACT same problem with my '92. Did you ever get the situation resolved?
Share This Page
