Turn key on a wot chatters making fuel pump come on and off car won't start. relay located on pass inter fender What connection does it have with fuel pump?? was running fine just hapened Car is 89 5.0 5 speed. Help
there is no sign of heat on the connection or relay the tsp was was replaced recently. was running fine just had major overhall almost all parts are new completely stock running all polution equipment. motor only idles sounds like spark is completely retarded. will not stay running. pulled codes 34 81 82 85 thank you for you reply. this wot thing has got me chattering any help would be appericated.
The motor was timed at 10 dagrees with spout out of Dis . I don't seem to make any difference in starting with the relay out. I cleaned the contacts on the relay and used some electrical gel and the chatting stoped. but car don't run if it catches it will idle like it is late on time barley turns over. What next
