Hey guys,
About a month ago my check engine light came on and stayed on. Went to AutoZone and they pulled the code and said that the left bank was running lean. They suggested some premium gas and some fuel injector cleaner, which didn't solve the problem. They then suggested the o2 sensor, which I haven't gotten a chance to replace yet.
Just this week, I've had additional problems, however. First, when putting the car into neutral, or pressing the clutch pedal, the engine stays at the same RPM as when it was in gear for about 10 seconds, then idles down, and sometimes almost seems like it will stall. When I first start the car, and wait for it to run through the initial idle up and down, it also tends to stall, but only once.
Could this all be related to the o2 sensor or should I be looking at something else? Thanks!
-Justin
-Justin
