Question when you pull the spout out and check your timing and re-set it then you put the spout back in isn't the timing supposed to move a little...I put the spout in and the timing stayed the same...
Does the timing change when you rev the car with the spout in? Spout out and revving should keep the timing locked. It's possible that the tune at whatever said rom or cell window is the same. Could be coincidence.
That I didn't check Nick duh...lol..I thought when you put the spout in the timing advanced slightly...didn't think to rev the motor and see If it moved...thanks...I just wanted to make sure the timing was were its supposed to be...I had the dist marked it looked like it moved...
