Cleaning out cylinder/Pistons..Lots of help
latham83
496
Hey i read a couple posts and every tells ya to use different things..
What I need to do is clean off the carbon deposit on top of the pistons..what do i use for that? then i need to clean out my cylinders themselves..since they have alittle crud sitting in the bottom of em and ****..and THEN AFTER i clean the top of the pistons and the surrounding area with whatever u guys tell me to use, what do i rub in there or put in there to have them sit and be ready for heads...do you leave some oil in there before you put the heads on ? or should they be crystel clear of all fluids..i dont know and i need to know cuase its important..thanks guys..
ALSO what works good to clean the engine itself, like the outside block..its gunked with oil and grime
User the gasket scraper & finish it off by vacuuming the loose particles out and spraying it all down with WD40. Clean the WD40 off the head & block surfaces with some solvent or gas before you put the gaskets on.
Plan on changing the oil after 1-2 hours of run time. This will wash the loose dirt & gasket material down in the pan and allow it to be drained out when you change the oil.
Wait until you get the heads back on and running good to clean the engine. Then use some Gunk spray on engine cleaner & a high pressure sprayer like the one at the coin operated car wash. Works great as long as you don't spray the distributor too much.
i think a few more details would be helpful - is this an assembled shortblock - or is it dissasembled? I assume you are referring to a dissasembled motor. Carb cleaner - the type you buy in a bucket that is meant for soaking an entire carburetor - works well for loosening up the grime on the pistons. YOu can just strip the rings off and drop the whole rod/piston assembly in there. After that, a high pressure blast off will get a lot of crud off. After that, if you put the rod carefully in a vice, an old piston ring works very well for scraping off the carbon on the top of the piston. You can also use a broken ring to scrape the ring lands of the piston to get rid of all the carbon. As far as the block goes - just a good engine degreaser and a 3M scrubby pad will do wonders. You should probably wear gloves though - that stuff is nasty. I would follow up by washing the entire block VERY well with detergent and water.
If instead you are referring to an assembled shortblock just as you are swapping heads, any carbon you scrape off might find its way into the motor, and cause more problems than it solved. My .02 - hope this helps.
ok i dont think u are understanding though what i did here..every thing is pretty much off of the engine...my heads are off, intakes, distributor, wiring..etc.
NOW i need to clean the pistons and the crud out of the cyl WHILE the pistons are in the position they are. what do i use.and how do i do it..AND VERY IMPORTANT QUESTION> HOW are the pistons and the cylinder itself supposet to RIGHT BEFORE the heads go on..what shouldi wipe it out with..what should i coat it with..i need to know what is suppose to be in there?
