i got my new adjustable cable, but it seems like its shorter than mine now. However, my it is for my car and i dont know how to take out the old one and put in the new, please help me out. Where does the "bolt" end go?
bolt end goes onto clutch fork on driver's side of the transmission. follow the cable down and you will see where it goes into a cover...take out the bolt and you'll have everything fall into place from there.
the other end hooks onto your quadrant (should be directly above accelerator pedal)
ok, i know it goes onto the quadrant, but the new cable only has about 8 inches of cable out the end of the tube on the quadrant side. Is the quadrant that close to the firewall?
oh and i got a firewall adjuster, and i thought i was supposed to take off the rubber part from the cable and slide the adjuster onto it, but it doesnt fit.
you have to trim the plastic tabs off the cable for the FWA to fit. look on MM&FF's website, they had an article 9/03 about the install....8" should be just about right to reach the quad
