Drivetrain Clutch Cable Keeps Breaking.
Discussion in 'Fox 5.0 Mustang Tech' started by kody baier, May 27, 2013.
  1. So i have a 91 gt and i just got the clutch and clutch cable replaced. I have been breaking clutch cables left and right for the past month. All of the clutch cables have been non-adjustable oem. I haven't been "hard" on my vehicle. So i hope some one can point me in the right direction because I don't know what to do.
  2. are they routed right ? by oem you mean ford or parts store replacement ? could be melting on the header or too close and the heat is fraying the wire .
    Sent from my iPhone using my fingers
  3. Are you trying to tie it to the fenderwell like it came from the factory? If so, don't. Run it forward of the headers and down next to the engine mount for a nice straight kink-free shot to the clutch fork.
  4. [Dude. I Had The Sane Deal. I Went To Advance Auto And SpenT A Bill On A Zoom Adjustable And Put Hat Slave And Problem Solved
    quote="kody baier, post: 8730783, member: 192655"]So i have a 91 gt and i just got the clutch and clutch cable replaced. I have been breaking clutch cables left and right for the past month. All of the clutch cables have been non-adjustable oem. I haven't been "hard" on my vehicle. So i hope some one can point me in the right direction because I don't know what to do.[/quote]
  5. Well the first one melted beause of the headers so we put a heat shield next to. Then the next one i stretched. Then the next one broke out of the firewall. All of the cables have been ran the same way. They are oem from different stores.
  6. If you are getting them from parts houses then they are not "OEM". People including myself have lots of problems with parts store replacement cables. Get a ford cable or the one from maximum motorsports. I got the one from MM and there is a very noticeable difference between it and the parts store cables I kept breaking.
    toolow91 likes this.
  7. Like I said earlier they are not oem read the link I sent you they actually dissected the cables to show U
  8. I am with the other guys, get the cable from Maxium Motorsports.
  9. Alright I will go with that. Thanks for all of the help
  10. I'd add an aftermarket quadrant and firewall adjuster as well....make life much easier.
    Sent from my XT907 using Tapatalk 2
  11. i was breaking cables for a while between the clutch pedal and the firewall adj, i finally figured it out it was where the cable goes thru the whole in firewall the cable was rubbing alignment was off
