Electrical Code 157 Maf
Discussion in '1994 - 1995 Specific Tech' started by 1slow5.0h, Feb 8, 2014.
  1. 95 gt, I replaced the maf n getting a code 157 maf below minimum voltage along with a couple other codes. Could this b a wiring prob coming from the harness or something? How would I go about checking that?
  2. Code 66 or 157 MAF below minimum test voltage.
    Revised 10-Feb-2014 to add 95-95 Mustang code 157 and 94-95 ECC diagram
    Insufficient or no voltage from MAF. Dirty MAF element, bad MAF, bad MAF wiring, missing power to MAF. Check for missing +12 volts on this circuit. Check the two links for a wiring diagram to help you find the red wire for computer power relay switched +12 volts. Check for 12 volts between the red and black wires on the MAF heater (usually pins A & B). while the connector is plugged into the MAF. This may require the use of a couple of safety pins to probe the MAF connector from the back side of it.
    Computer connector for 88-93 5.0 Mustang
    Diagrams courtesy of Tmoss and Stang&2Birds
    ECC Diagram for 88-90 5.0 Mustangs
    ECC Diagram for 91-93 5.0 Mustangs
    94-95 Diagram for 94-95 5.0 Mustangs
    There are three parts in a MAF: the heater, the sensor element and the amplifier. The heater heats the MAF sensor element causing the resistance to increase. The amplifier buffers the MAF output signal and has a resistor that is laser trimmed to provide an output range compatible with the computer's load tables. Changes in RPM causes the airflow to increase or decrease, changing the voltage output.. The increase of air across the MAF sensor element causes it to cool, allowing more voltage to pass and telling the computer to increase the fuel flow. A decrease in airflow causes the MAF sensor element to get warmer, decreasing the voltage and reducing the fuel flow.
    The MAF element is secured by 2 screws & has 1 wiring connector. To clean the element, remove it from the MAF housing and spray it down with electronic parts cleaner or non-inflammable brake parts cleaner (same stuff in a bigger can and cheaper too).
    89-90 Model cars: Measure the MAF output at pins C & D on the MAF connector (dark blue/orange and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
    91-95 Model cars: Measure the MAF output at pins C & D on the MAF connector light blue/red and tan/light blue) or at pins 50 & 9 on the computer. Be sure to measure the sensor output by measuring across the pins and not between the pins and ground.
    At idle = approximately .6 volt
    20 MPH = approximately 1.10 volt
    40 MPH = approximately 1.70 volt
    60 MPH = approximately 2.10 volt
    Check the resistance of the MAF signal wiring. Pin D on the MAF and pin 50 on the computer (dark blue/orange wire) should be less than 2 ohms. Pin C on the MAF and pin 9 on the computer (tan/light blue wire) should be less than 2 ohms.
    There should be a minimum of 10K ohms between either pin C or D on the MAF wiring connector and pins A or B. Make your measurement with the MAF disconnected from the wiring harness.
    Actually MAF pins C & D float with reference to ground. The signal output of the MAF is a differential amplifier setup. Pins C & D both carry the output signal, but one pin's output is inverted from the other. The difference in signal between C & D is what the computer's input circuit is looking for. The difference in the two outputs helps cancel out electrical noise generated by the ignition system and other components. Since the noise will be of the same polarity, wave shape and magnitude, the differential input of the computer electronically subtracts it from the signal. Then it passes the signal on to an Analog to Digital converter section inside the computer's CPU chip.
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/
    Ignition switch wiring
    Fuel pump, alternator, ignition & A/C wiring
    Computer,. actuator & sensor wiring
    Fuse panel layout
    Vacuum routing
    #2 jrichker, Feb 10, 2014
  3. Why'd you replace the maf in the first place.
    Did you get the check engine light brfore replacement?
    Did you clear codes after replacement, and then check codes?
