Code 67 Help Nss
Discussion in 'Fox 5.0 Mustang Tech' started by erzenble, Jul 28, 2014.
  1. Hi I have an 86 5.0 in my mazda b4000 truck with an 83 aod. I am getting the code 67 and thinking it could be the problem of my idling issues. Does anyone know how to get rid of it? What I don't get is when I try to start my truck in drive it won't start yet I still get the code.
    Where would the switch be located?
    Also what color wire would the wire connected to pin 30 be? Could I ground this out to check on the idling issues and get codes?
    Thanks!
  2. Code 67 –
    Revised 2 Nov 2012 to add definition of the NSS functions for both 5 speed and auto transmissions
    Cause of problem:
    clutch not depressed (5 speed) or car not in neutral or park (auto) or A/C in On position when codes where dumped. Possible neutral safety switch or wiring problem. This code may prevent you from running the Key On Engine On tests.
    External evidence from other sources claims that a code 67 can cause an idle surge condition. Do try to find and fix any issues with the switch and wiring if you get a code 67.
    What the NSS (Neutral Safety Switch) does:
    5 speed transmission: It has no connection with the starter, and the engine can be cranked without it being connected.
    Auto transmission: It is the safety interlock that prevents the starter from cranking the engine with the transmission in gear.
    What it does for both 5 speed and auto transmission cars:
    The computer wants to make sure the A/C is off due to the added load on the engine for the engine running computer diagnostic tests. It also checks to see that the transmission is in Neutral (5 speed and auto transmission) and the clutch depressed (T5, T56, Tremec 3550 & TKO)). This prevents the diagnostics from being run when the car is driven. Key On Engine Running test mode takes the throttle control away from the driver for several tests. This could prove hazardous if the computer was jumpered into test mode and then driven.
    The following is for 5 speed cars only.
    The NSS code 67 can be bypassed for testing. You will need to temporarily ground computer pin 30 to the chassis. Computer pin 30 uses a Lt blue/yellow wire. Remove the passenger side kick panel and then remove the plastic cover from the computer wiring connector. Use a safety pin to probe the connector from the rear. Jumper the safety pin to the ground near the computer.
    Be sure to remove the jumper BEFORE attempting to drive the car!!!
    [​IMG]
  3. Code 67 –
    Cause of problem:
    [​IMG]
    [​IMG]
    See the following website for some help from Tmoss (diagram designer) & Stang&2Birds (website host) for help on 88-95 wiring http://www.veryuseful.com/mustang/tech/engine/ Everyone should bookmark this site.
  4. Thanks jrichker. Do you happen to know where the switch might be located on an aod?
  5. On the external shifter mechanism...
