As my car sits for the winter, I'm getting a list of things I'll need to do a regular maintenance routine on it. Please note, I'm not the most mechanically inclined when it comes to cars, but I've got several friends that are mechanics.
Item 1: Are COPs something that should be replaced? The car is a 99 with 18000 miles on it. Do COPs wear out like spark plugs, belts/etc? How much work's involved with this? I plan on changing the plugs anyway, so I pretty much have to remove the COPs anyway. Just need to know if there's a benefit to replacing them.
Item 2: Transmission fluid. It's a m/t, is this something that should be done as well? If so, how difficult is it?
Item 3: Bushings/bearings. I can only assume it'd be beneficial to change the various bushings on the suspension/etc, especially after 10 years. My question is, what's a good replacement (I'm assuming urethane) and what's an approximate cost (cost applies to the COPs as well, if needed)?
Item 4: Fuel filter. How difficult is this to change?
Other normal yearly stuff includes, air filter, oil/filter change. I'll probably flush the radiator, and if recommended, the intercooler (is this necessary?).
Any advice on the above would be appreciated.
