Converting to braided fuel lines
chrome302jr
15
Va
I am running an EFI 5liter, with stock rails and nylon fuel lines. During my engine swap I had to do some custom work with the fuel lines and want to upgrade to braided lines for security.
I have found the Russel fittings to go from the stock rails to 8AN supply and 6AN return lines, then plan to run 8AN supply and 6AN return lines, using an 8AN fuel filter. However, what fitting should I use to connect to my stock intank pump assembly. Is there a fitting to go from 8AN/6AN to the bundy tube connections on the pump assembly? Ive looked at Ron Morris Perf and Summit/Jegs. Any ideas? Thanks.
