Coyote Weekend
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by TOOLOW91, Oct 20, 2013.
  1. TOOLOW91
    TOOLOW91 Mustang Master
    3,382
    1,321
    154
    S.I.NY
    *Swap list*
    -AJE K member and control arm kit ( used with 468 bbc. They made the mounts for coyote and fit is flawless. Same for trans cross memeber.
    -Mishi moto Radiator
    -Flexalite 3300cfm fan
    -Coyote Motor
    -Control Pack
    -3/4 heater hose
    -2 90 degree 3/4 hose adapters to route heater hoses
    -Ford racing ecm pins for speed sensor fix (Stalling issue as noted by our sites fearless leader in BTC)
    -Skinny kid racing manual brake kit
    -Gas pedal bracket adapter
    -Aeromotive FP regulator.
    -6an to ford fuel line adapter.
    -Assorted an fittings and line depeneding on your fuel system We used magna fuel and a sump tank. Supercharger is in the future.
    -Transmission ( We used a t56)
    -Speed sensor plug.
    -Rev lock out plug
    -Weather pack plug for rev lights
    -Ford racing steel flywheel
    -Centerforce Dual Friction clutch
    -MM Clutch cable and quadrant
    -Bell housing
    -Bell, Trans, Starter bolts. All from ford.
    -Pa performance mod motor starter
    -Boss 302 alternator kit.
    -BBK Swap headers and mid pipe
    -Florida 5.0 cluster. (Still to be installed)
    -03-04 cobra drive shaft- fox-body v8 rear yolk with a hybrid 1330 , 1310 u joint.
    -Flaming river Manual rack and steering shaft
    -Upr bump steer kit
    I drove the car to day let me tell you the car drives and performs flawless. Few little things we need to tie up but all in all its awesome.
    ------------- UPDATE AS OF 10-21-13^^^-------
    Well guys me and my buddy john did a coyote swap for a friend of mine figured I would post some shots we did the whole swap in 15 hours over sat and today , Car is running and driving . .
    only thing left is Florida 50 cluster and wire the rev lock out for t56 .
    any question if somone is ever gonna do the swap shoot me a pm I can help out !
    gyru9udy.jpg azajehad.jpg uvu7e5as.jpg epy6usy2.jpg ezaguta2.jpg tavuhetu.jpg
    #1 TOOLOW91, Oct 20, 2013
  2. mikestang63
    SN Certified Technician
    Aug 27, 2012
    4,519
    1,344
    154
    In the garage
    nice work. That is a swap most of us would love to do. Where did you obtain the motor? How about posting a list of parts needed?
  3. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    I can try and get it all together the motor has been sitting at my garage brand new in the crate from LMR
  4. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    I will do it tomorrow the list
    A5literMan likes this.
  5. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    final shot .
    last year we built this car with a 468 bbc 12:1 compression and he hated it after so here we are
  6. GroverDill
    GroverDill GoldMember
    Aug 18, 1999
    4,934
    390
    114
    Rathdrum ID 83858
    I would love a fox like that
    Dare I say my car is just too much for the street.
  7. Bullitt95
    Bullitt95 Active Member
    Jun 13, 2007
    1,321
    27
    49
    Al Ain, United Arab Emirates
    A Fox with a Coyote. That's funny. Should be a marriage made in heaven. ;)
    TOOLOW91 likes this.
  8. elarm1
    elarm1 Advanced Member
    Dec 17, 2010
    995
    276
    74
    N.Va
    mind me asking how much the package costs?
  9. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    he has 11,500 total in the swap EVERYTHING except the TRANS is new .
    TRANS is a t56 out of a cobra with a 26 spline input shaft upgrade
    I promise in gonna work on a swap list later for anyone interested
  10. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    Love your car , I think. a fredde brown would change that
  11. GroverDill
    Aug 18, 1999
    4,934
    390
    114
    Rathdrum ID 83858
    I am saving pennies for it!
  12. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    Check the list out
  13. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    quick shot of the car as well yes it is very clean
  14. 95BlueStallion
    95BlueStallion Advanced Member
    Feb 22, 2007
    1,888
    199
    74
    Cedar Rapids, Iowa
    Damn dude, I thought you swapped it into your car! I would gladly trade my '11 for a properly swapped car such as your friend's.
  15. MikeH686
    MikeH686 Mine is only two inches though.
    Oct 11, 2011
    2,064
    403
    104
    Waldorf, MD
    Let me know if you need help with the fiveoh cluster
  16. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    I may need help sir I will keep you posted , looks straight forward but I have to run speed sensor, o/p and temp separate . I believe I can tap into the stock foxbody lead for voltage and obviously blinkers I will keep you posted . Thanks dude
  17. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    I wish I don't have that extra cash around I would loved too but I was just the one who performed the swap with another friend
  18. MikeH686
    Oct 11, 2011
    2,064
    403
    104
    Waldorf, MD
    Yeah its all straight forward they have more instructions then autometer gives you lol i got the sport comp pro comp combo and dont use the t taps just cut the wires from the stock plug and run your own connector i dont trust t taps
  19. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    I was gonna get fancy and use single weather pack plugs maybe like I did for the fan and sensors so it can be removed if needed
  20. TOOLOW91
    3,382
    1,321
    154
    S.I.NY
    His are cobalt , I didn't look but are all the lights and the ground all together so it's one tap and all the gauges will light ?
Share This Page
