Different types of pistons that can be used when rebuilding..
Discussion in 'Fox 5.0 Mustang Tech' started by emagdnim, Jun 27, 2005.
  1. emagdnim New Member
    Feb 5, 2003
    Message Count:
    372
    What different types of pistons are there? .. I heard flat top truck pistons will help raise compression is this true? Also are there domed pistons that can be used with a larger cc head to raise the compression so one would not have to mill the heads? What pistons do you guys recommend? Thanks
  2. TIMMY2734 Founding Member
    May 17, 2002
    Message Count:
    1,332
    36
    Queens, NY
    flat tops, dished, domed,
    Look around sites and youll be able to find a piston for your application.
    Look at coast high, or just check out ADPerformance. Brian will hook you up with what you want and what you need to know
    Sponsored Ad
  3. emagdnim New Member
    Feb 5, 2003
    Message Count:
    372
    Cool thanks for the info man.. much appreciated
  4. ExplodingGopher New Member
    Jun 11, 2004
    Message Count:
    542
    The mistake on the lake (Ohio)
