ultrastang
A fixed caliper is superior in performance to and equivalent floating caliper, if only by a little bit. Fixed calipers are more expensive then the floating calipers, they require more maint. and over time can require recentering on the rotor. I imagine all of these together make a good argument for most manufacturers to use a floating design. You will notice on the true high end cars that they don't use floating calipers, they don't need to save cost on production and they expect people to be ok with the added maint. cost down the line.
After doing some research, I found that the Dodge Viper utilizes gigantic brakes with massive fixed calipers, both front and rear.
The'03 SN95 SVT Cobra was the top-of-the-line performance offering from Ford with an MSRP of $37,845.00 dollars. The Viper would definitely fall under the definition of a "true high end car" with its long list of exotic parts and highly expensive fixed-caliper braking system and an MSRP price tag of $79,995.00 dollars.
One would expect the Viper to totally blow the ['Terminator'] Cobra away in a braking contest, but the facts will soon be revealed that proves otherwise.
Statistics: The Cobra and Viper are within the same weight classification. The '03 Cobra weighs 3,255 lbs. An '03 Viper weighs 3,380 lbs., a difference of only 125 lbs. The Viper costs $42,150.00 dollars more than the SVT Cobra. In fact, you could have bought two brand new '03 Cobras for the price of one '03 Viper and still had $4,305.00 dollars left over.
The '03 Cobra had twin 40mm pistons in a ['lowly budget'] floating front caliper and a single 38mm piston in the ['lowly budget'] rear floating caliper. Front rotors for the Cobra were 13". Cobra rear rotors were 11-5/8". The Viper had massive, dual-opposing 44/40 fixed front calipers with very large dual-opposing 42/38 fixed rear calipers with enormous 14" rotors all the way around.
In a Car & Driver stopping shootout, the '03 Viper went from 60MPH down to zero in 129 feet. The '03 Cobra with its smaller 'budgetary' floating caliper brakes stopped the car in 121 feet --a full 8 feet sooner than the more-than-twice-as-expensive, "better" fixed caliper braked Viper.
One would expect the Viper's highly expensive and 'better' fixed caliper brake system to be no contest against a budget, floating caliper brake system of a Cobra, but the facts show the Cobra's floating caliper brake system lived up to the 'Terminator' name against a vehicle with supposedly 'superior brakes' --and at a cost of less than twice that of the Viper.
