Having problem getting my Distributer Bolt loose I can not get "on top " of it or get a could enough angle from the side is there a easier way???? Some one tightnen the hell out of it.
well first soak it in some lubricant (power lube, wd40 something like that) then get a swivel socket or a swivel to go inbetween the socket and extension.. just pray it doesn't break off
ahh did someone say impact wrench???????? eeekkk.
i use a 1/4" socket and 1/4 swivel and 1/4 extension or two. you will want to adapt it to 3/8 and use a 3/8 ratchet if its in there that tight. should give a nice click and loosen up or break off. do as said, and soak it in pb or wd.
with the 1/4 stuff, the socket fits pretty nice and square.
good luck.
Has anyone mentioned a distributor wrench? Buy one if you don't have one. Should have 9/16 on on side and 1/2 on the other. Makes getting to that bolt very simple.
Yup.. I second the distributer wrench... If your short on funds, you can even get by with the cheapy from Pepgirls.. for $4.99... It works every time, and requires no funky angles, swivels, or swearing.. well ... swearing is optional...
