I had taken out the distributor awhile back and marked everything but after a bit I changed the crank position. And when I put the distributor back in I thought I had it right but when I tried to check my timing and never saw the marks on the damper. So I set the crank at TDC and the rotor was pointing at the #3 not the 1 plug. So I pulled out the distributor and set the rotor at #1 but now I can’t get the car to start. I have heard that you could be at TDC for the intake stroke and it’s different for the exhaust stroke. Could this mean that I have to turn the rotor all the way around?
