Suspension Do I Need Castor Camber Plates
Discussion in 'Fox 5.0 Mustang Tech' started by Casey2552, Sep 20, 2013.
  1. I'm not that knowledgable on suspension I have lowering springs do I need cc to get alignment right
  2. Yes and no... They are the easiest/best way to get correct caster/camber. However you can slot the strut bolt holes to achieve the same result but that method has it's own likes/dislikes....
    Just buy the cc plates and be done with it.
  3. Yeah that's what I figured , it will look nice to under the hood any suggestions for brand or best plates for good price
  4. I simply prefer the more positive adjustment with the aftermarket plates. The factory rubber bushings in the top of the plates you currently have are most definitely worn and I would recommend replacing them if your budget so allows.
  5. Thanks , yeah I will probably order those
