E303 ?
undercover50
32
After my e303 cam was installed it felt like my car is down on power sometimes and then other times is would be more powerful the cam has been in my car for two days now is this normal is the computer just adjusting to the cam? Thanxs
Car should always run the same. I know that somedays I run better than others and I mean by .10 or .2 at the track. Depends on atmospheric conditions. But you sound like you are having much more of a problem than what I stated above. My car has an E cam and it runs great.
What else do you have done to your car beside an E cam?
I know what the problem was My clutch was going out and with the added power the stock clutch woould not hold the power. First gear would pull like a monster but then as the clutch got hot the car would rev higher but the car would not pull as hard...... I have a trick flow intake, 65mm throttle body,pullies,bbk hearers, x pipe, 2 chamber flows E303 cam, and 3:73 gears hoping for low 13 at the track in my notchback
