You will need to tap both the + and - on the VSS. One stangnetter found he could not get an accurate reading with the VSS connected to both the speedo and the computer. He ended up disconnecting the computer and using the VSS to drive only the speedo. That works Ok, it just generates a code 27 or 29 for a VSS circuit fault.
