Engine Build Choices - What Would You Choose?
Discussion in '1979 - 1995 (Fox, SN95.0, & 2.3L) -General/Talk-' started by JTB321, Oct 27, 2013.
  1. Agreed. Either one of the 58cc would be optimal. You can run either one with an e cam. The e cam is going to cost you some power and driveability over the Trick Flow cam.
  2. Yes. That's the stage 1 cam. Don't know if you checked into yet or not but the tfs topend kit comes with the 170cc heads,stage 1 cam,valvetrain,gaskets,bolts,etc for around 2500$ everything you need to upgrade and cheaper than piecing it together.
  3. Yes, that's the cam Trick Flow sells specifically to go with their 170cc heads.
