I just got done doing a V8 swap in my 93 4cy. Its a new 306 with a single turbo, Im running 42lbs injectors with a 75mm Pro-M Blow through mass air meter, I also have a msd 6btm, I am running a stock cam, 92 or 93 harness and stock computer.
Ok now to the problem. I started the car for the first time the other day after completing the swap. The car started up on the first try, and ran fine all the way up the 180deg, and held steady, But shortly after it reached its running temp it went from running smooth to developing, what seems like a miss fire, the engine shakes, it does not clean up when I rev it, and has a poping noise exiting the open down pipe(sounds like a small back fire). But here is the weired part, while its running bad if you shut the car off and then start it again, it goes back to running smooth again, but after a few minets it instantaniously reverts back to what seems like a miss fire. Mind you this is not while driving the car, it is just idleing in the driveway. Any help would be greatly appreciated, thaks in advace. (Hopefully)
